Most custom domain activation issues come down to a few DNS settings. Check these with your domain provider:
  • DNS records aren't in place yet. Add the records from Adding a custom domain before you activate the domain in Ghost.
  • More than one A record. Keep a single A record for the domain, pointing to Ghost's IP address. With several, visitors are sent to each one in turn, so your site only loads some of the time. Remove any left over from a previous website.
  • Cloudflare proxy is on. If you use Cloudflare, set the Proxy status of every record for Ghost to DNS only. Proxied records can't be reached by our servers, so the domain can't be activated. See Cloudflare domain setup.
  • Root and www don't match. The domain you activate in Ghost needs to match your DNS records exactly. If your CNAME is on www, activate www.yourdomain.com, not yourdomain.com.
  • DNS hasn't updated yet. Changes can take up to 24 hours to reach everyone.
Once your DNS records are correct, activate the domain from the Ghost(Pro) → Domain area as the site owner. Your SSL certificate is set up and renewed for you automatically.
These records don't affect email on your domain, as long as you leave your MX records in place.
If your domain still isn't connecting, contact Ghost(Pro) support with the domain name and we'll take a look.
