If you suspect that your site's credentials might have been compromised, you should use Reset authentication to rotate all your site's keys and secrets. Every staff user — including you — will be logged out and forced to set a new password.
This is a destructive action. All API keys will be reset, and all staff passwords will be reset and existing sessions signed out, including you.
How to reset all authentication
  1. Go to Settings → Advanced → Danger zone.
  2. Click Reset.
  3. Ghost rotates your keys, resets staff accounts, and signs everyone out. You'll land back at the sign-in screen.
  4. Each staff user will be prompted to set a new password on the next sign-in.
Things to know
  • Integrations will stop working. Each API key in Settings → Advanced → Integrations is replaced with a new secret. You'll need to reconfigure each integration with the newly generated secrets.
  • Members and their subscriptions are remain untouched. They stay signed in and can continue to sign in with magic link emails as usual.
  • Settings, themes, posts, pages, tags, and settings are all untouched. Only authentication credentials are reset.
