đź§Ť
Manage, track, moderate, and support your members with ease using the Ghost members dashboard.
The member dashboard keeps everything in one place, allowing you to search for members, add notes, import and export lists, create segments, and more. This makes it easy to perform simple member admin tasks and keep track of how your membership business is performing.
Filtering and bulk actions
Powerful filtering options allow you to segment your list using any number of filter parameters and conditions, to carry out bulk actions with ease.
Members can be filtered by label, email subscription status, member status, billing period, emails opened, emails sent, email open rates, and more.
Segment your list using any number of filter parameters
Additional filters can be added by clicking "Add filter" and selecting your criteria
Save view
Once you've filtered your member list, the filtered view can be saved for quick access from within Ghost Admin, anytime. To save your filtered your members, click Save view, to name and save the filtered view.
Once saved, the view will appear under the Members area in Ghost Admin.
Members can be filtered by:
Basic Newsletters Subscription Email
Name Subscribed Membership tier Emails sent (all time)
Email Unsubscribed Member status Emails opened (all time)
Label Email disabled Billing period Open rate (all time)
Newsletter subscription Stripe subscription status Received email
Last seen Paid start date Opened email
Created Next billing date Clicked email
Signed up on post/page Subscription started on post/page Responded with feedback
When filtering "All newsletters," here's what the terms mean:
  • "Subscribed to at least one": Members who can receive at least one newsletter
  • "Unsubscribed from all": Members who have turned off all newsletters
  • "Email disabled": Email addresses that have been disabled by Ghost because they are unreachable or because messages have been marked as spam
Once you've filtered your members, clicking the "..." icon in the top right corner opens the bulk action options, which allow you to export, apply labels, remove labels, and unsubscribe selected members from email:
Filtering is useful for many things, here's some of the most common ways to use filtering and bulk actions from the member dashboard:
  • Find out who your most engaged members are using the open rate filter.
  • Filter members based on custom fields.
  • Unsubscribe unengaged members from receiving emails to improve deliverability.
  • Add labels to a filtered segment of your audience so you can deliver emails only to them, and find them again easily in the future.
  • Use filtered segments to export a list of your members for use in other tools.
  • Discover which members converted from a specific post, using the Signed up on post/page filter.
Using bulk delete
When selecting any segment of your members based on label or status, click the "..." icon to access the bulk delete menu:
Confirm that you'd really like to delete the selected segment of members to begin the bulk delete action.
Bulk deletions have no effect on active Stripe subscriptions, and a backup of the members you have deleted will automatically be downloaded to your device before deletion takes place.
Member profiles
Each member has an individual profile with all of the information you'll need at a glance:
Name & notes
You can add a member's name and additional notes about their subscription or any other useful information that you want to save for later in the basic info section.
Custom field responses
If using custom fields, you can see the responses from your members, based on the custom fields you’ve added to Portal.
Email stats and activity
See how engaged individual members are with your content right on their member profile page, with average open rates, and an activity feed of their most recent actions.
Subscribed to newsletter
This allows you to manually subscribe or unsubscribe people from receiving emails sent from Ghost. All email newsletters sent from Ghost also have an unsubscribe link by default which will change a members status to unsubscribed when clicked.
Labels
Labels can be used to segment your members, such as VIP members. It's possible to add labels manually or via a CSV import.
It's also possible to apply labels automatically via embeddable signup forms, via the API in your theme's signup form, or using the Zapier integration.
Quick access billing in Stripe
A handy link to the Stripe customer ID allows you to quickly access a member's profile in your Stripe account. This is useful if you need to address billing issues, change their plan or apply credit.
Check out the Stripe Dashboard docs to find out more about managing your Stripe account.
Signup info
An overview of when the member signed up, which referral source they found your content from, and which page on your site they were reading when they signed up. Read more about creating custom sources.
Further Reading
What should I do if my member is not receiving emails?
Follow these steps to troubleshoot delivery issues, and help point members to the most common solutions.
