When members decide to upgrade to a paid tier, they will complete their purchase via a Stripe Checkout page. This page can be customized directly within Ghost Admin, from the Settings > Tiers > Checkout area.
Look & feel
In order to customize your design, you will first need to enable the checkout design settings. When enabled, this will override the checkout styling in Stripe.
The available options that can be customized include:
- Background color
Apply a custom background color to your checkout page - Accent color
Use your site’s accent color, or select a custom accent color for your Pay button - Corners
Choose between square, rounded or pill corners - Checkout font
Choose a custom font that fits your brand design
You can also preview how your changes will display during checkout using the Preview in Stripe option, allowing you to see how checkout will look for each tier.
When finished making your changes, hit Save to push them live on your publication.
