The Starter plan is available once your site only uses the features included in the plan. Before switching, make sure your site matches this checklist:
  • Theme: Use the official Source theme. Custom themes aren't supported on Starter
  • Custom sending domain: If you have this feature enabled, you can remove it from the Ghost(Pro) → Domain area. Your newsletters go back to being sent from your default @ghost.io address.
  • Analytics: Turn off web analytics from the Settings → Analytics area
  • Stripe: Disconnect Stripe from the Settings → Membership → Tiers area
  • Staff: Reduce your team to one staff user in the Settings → Staff area (you can either suspend additional staff users, or make them contributor role staff, as neither count towards plan limits)
  • Newsletters: Archive additional newsletters in Settings → Newsletters, so only one newsletter is active
Then go to the Ghost(Pro) → Billing as the site owner and select the Starter plan.
Disconnecting Stripe means your site can no longer offer paid memberships, or accept tips & donations
Compare what's included in each plan on our pricing page.
