A list of available keyboard shortcuts can be found in the post settings within the editor.
                        0:00
                            /0:20
                    This list will reflect shortcuts available on your current operating system. If you move between devices (for example from Windows to MacOS) please keep in mind that the shortcuts will change.
A shortcut may not be available if you have made settings changes on your device that override the expected defaults.
