You can easily migrate your posts and subscribers from Substack to Ghost in just a few clicks, using the Substack migrator in Ghost Admin.
Run the migration
The Substack migrator allows you to quickly import content and members from your Substack to your Ghost publication. You can access the migrator tool from the Settings → Advanced → Import/Export area of Ghost Admin.
![](https://ghost.org/help/content/images/2024/01/admin.png)
It's helpful to log in to your Substack account before running the migration in Ghost Admin.
1. Enter your Substack URL
To start the migration process, enter the public URL to your Substack, and click Continue.
![](https://ghost.org/help/content/images/2023/12/enter-url.png)
2. Export content
Next, click Open Substack Settings. If already logged into Substack, this will take you directly to the location of your Substack account where an export can be generated.
![](https://ghost.org/help/content/images/2023/12/import-content.png)
Click Create new export, and then download the zip file that's generated after the export is completed in Substack.
3. Upload content
Once your export has been downloaded, return to the migrator window in Ghost Admin, and select Click or drag file here to upload, and navigate to the zip file you downloaded from Substack, once uploaded click Continue.
If you're unsure of where the file was saved, check your Downloads folder.
4. Export free subscribers
Next, it's time to import your Substack subscribers. Click Download free subscribers from Substack, to trigger a CSV file download of your subscriber list.
Once downloaded, select Click or drag CSV file here to upload and navigate to the CSV download, and click Continue.
![](https://ghost.org/help/content/images/2023/12/import-free-subscribers.png)
5. Export paid subscribers
Next, it's time to import your Substack subscribers, if you have them. Click Download paid subscribers from Substack, to trigger a CSV file download of your subscriber list.
![](https://ghost.org/help/content/images/2023/12/import-paid-subscribers.png)
6. Review
Ghost will confirm the number of posts and members that will be imported to your publication. If satisfied, click Import content and subscribers to begin the import of your data.
![](https://ghost.org/help/content/images/2023/12/summary.png)
After a few moments, you'll see a confirmation message, confirming that your data was successfully migrated to your Ghost site.
Substack fees
Ghost does not take a cut of your revenue. Substack will continue to take 10% fees on your existing paid subscriptions. If you would like help getting payment fees removed, contact concierge@ghost.org.
Statement descriptor
The statement descriptor is what's shown on bank statements, and depending on how the account was set up, might include 'Substack' in the name. We recommend updating this in your Stripe public details settings.
If you encounter issues, and you're a Ghost(Pro) customer, reach out to our support team for further advice, or head to the forum for community support if you're self-hosting.
