Ready to breathe new life into your new Ghost site and import some content? Discover how to import content and images to your publication from other Ghost installs, or other platforms.
Imports in Ghost
The Ghost importer allows you to import content and images directly to your new publication from Substack, Medium, MailChimp and other platforms.
Access the importer from the Settings → Advanced → Import/Export area in Ghost Admin.
Migration guides
We have an array of migration documentation to help you move to Ghost from different platforms.
Migrating from Ghost to Ghost
If you're migrating from another Ghost install, the importer will handle the import for you using the Universal import option.
If you're migrating from a different platform that is not listed, your content needs to be formatted before it can be imported to Ghost. See our migration docs for guidance.
Image imports
The importer accepts both JSON and zip files, which means you can import your content and images at the same time by adding your files to the same zip file.
Handling large imports
Because image imports can be high in file size, it is recommended to break up your image import into multiple, smaller zip files. You can use the following tools to split up your zip files and your JSON files.
If you're migrating from another platform, keep in mind that each import would need to use the same file path structure found in the export generated by the platform (e.g. include the /content/images/ path).
If you encounter issues, and you're a Ghost(Pro) customer, reach out to our support team for further advice, or head to the forum for community support if you're self-hosting.
