The Ghost Bookmarker is a browser extension for Chrome & Arc, that allows you to seamlessly curate resources you come across while browsing the web, and add them directly to a new post in Ghost Admin with just a few clicks.
How it works
When viewing an article on a website, you can click the Ghost icon from within the browser toolbar, and the link will be captured as a Bookmark card within a new draft post in Ghost Admin.
You can optionally add notes to each Bookmark you insert, and your notes will appear as text within the editor, alongside your Bookmark card.
Once you publish a post containing Bookmarks added via the extension, a new draft post will be created automatically when adding new links via the bookmark tool in the future. This makes the process of curating links for a weekly roundup newsletter simple and efficient.
If you need help getting the Ghost Bookmarker setup, check out our integration guide, here:
![](https://ghost.org/images/meta/ghost-integrations.png)
