Quick-search for anything
⌘F
Major Versions & Long Term Support
Major version release dates and end of life support for Ghost.
VersionReleasedEnd of Life
Ghost 0.x2013Jan 2019
Ghost 1.x2017Jan 2020
Ghost 2.x2018Jan 2021
Ghost 3.x2019Jan 2022
Ghost 4.x2021Jan 2023
Ghost 5.x (Current)2022TBC
At any one time the current major version of Ghost is under active development, whilst the previous version is maintained as the Long Term Support version (LTS).
The current version of Ghost receives new features and improvements on a regular basis. The LTS version of Ghost will only receive critical security and stability fixes.
Once a version reaches End of Life it should be considered insecure.
The update guide describes the steps for updating from Ghost 1.0 or higher, to the latest version of Ghost.
If you’re running an 0.x version of Ghost, you’ll need to follow the update guide first to update to 1.0, as there is no direct update path from versions < 1.0 to the latest version.
