> ## Content Index
# Site navigation
- URL: https://ghost.org/help/updating-navigation/
- Published: 2023-04-18T09:59:07.000Z
- Updated: 2026-02-17T15:56:56.000Z
- Author: Ghost
- Tags: Getting started, Manual
Ghost makes it easy to update your navigation menus, so you can quickly make updates such as adding an about page to your main navigation, or a contact page in your footer.
## Primary navigation
Your site's navigation menu can be updated directly in Ghost Admin from the **Settings → Site → Navigation** section. By clicking on **Customize**, a new menu will pop up which allows you to add or edit items in your primary & secondary navigation.
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2026/02/settings-customize-navigation.png)
Navigation items can be dragged to rearrange order.
## Secondary navigation
If your theme supports it, you can also add **secondary** navigationlinks to your publication. These are commonly used in your footer, or in the top right corner beside your primary navigation.
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2026/02/settings-secondary-nav-items.png)
****Tip**: All tagged content exists in an automatically generated tag archive, which means you can add content categories to your navigation. For example: `/tag/news/` and `/tag/podcast/` can be used to add a News & Podcast navigation link.
### Adding Pages to your navigation menus
Once a page has been created in Ghost Admin, it is not automatically added to your site navigation.
To add a page you've published to your site navigation, you'll need to first copy the URL of the published page, and then insert this as the link for a new item label within the **Settings → Site → Navigation** area. Once saved, your link will then appear within the navigation on the frontend of your publication.
