> ## Content Index
# How do I switch to the Starter plan?
- URL: https://ghost.org/help/how-do-i-switch-to-the-starter-plan/
- Published: 2026-11-18T10:15:28.000Z
- Updated: 2026-11-18T10:15:28.000Z
- Description: Starter is available once your site only uses the features included in the plan.
- Author: Ghost
- Tags: FAQ
The Starter plan is available once your site only uses the features included in the plan. Before switching, make sure your site matches this checklist:
- **Theme:** Use the official Source theme. Custom themes aren't supported on Starter
- **Custom sending domain:** If you have this feature enabled, you can remove it from the **Ghost(Pro) → Domain** area. Your newsletters go back to being sent from your default `@ghost.io` address.
- **Analytics:** Turn off web analytics from the **Settings → Analytics** area
- **Stripe:** Disconnect Stripe from the **Settings → Membership → Tiers** area
- **Staff:** Reduce your team to one staff user in the **Settings → Staff** area (you can either suspend additional staff users, or make them contributor role staff, as neither count towards plan limits)
- **Newsletters:** Archive additional newsletters in **Settings → Newsletters**, so only one newsletter is active
Then go to the **Ghost(Pro) → Billing** as the site owner and select the Starter plan.
Disconnecting Stripe means your site can no longer offer paid memberships, or accept tips & donations
Compare what's included in each plan on our [pricing page](https://ghost.org/pricing/).
