> ## Content Index
# Newsletter template settings
- URL: https://ghost.org/help/email-design/
- Published: 2023-04-19T13:53:35.000Z
- Updated: 2026-04-21T18:32:54.000Z
- Author: Ghost
- Tags: Newsletters, Manual
Email newsletters in Ghost come with a polished, customizable HTML template that works beautifully across all major email clients.
Your newsletter’s design settings let you create emails that look and feel uniquely yours — from colors and typography to buttons and borders — keeping your brand consistent across web and the inbox.
To access these options, go to **Settings → Membership → Newsletter** and click **Edit**.
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2025/06/image.png)
## General settings
Here you can set the name and description of your newsletter, in addition to the sender name readers will see in their inbox.
### Email info
To set a custom sender name, and ‘reply-to’ email address for your newsletter, toggle to the **General** email newsletter settings.
- **Sender Name -** This will appear as the name your email newsletters are 'from' in a reader’s inbox, and will default to your site title unless customized.
- **Reply-to Email Address -** This is the email address used for when members reply directly to your newsletter.
If you'd like to change the **Reply-to** email addresses, enter the new email address to be used and click **Save**. This sends a confirmation email to the *new* email address, containing a link that must be clicked to verify and activate the email address.
If on the Publisher plan (or higher), and using the [custom sending domain feature](https://ghost.org/help/custom-sending-domains/), you can also configure a custom sender 'from' email address within your newsletter settings.
## Content settings
This section controls the elements that you’d like to show in your newsletter template, giving you fine-grained control over what readers see (and what they don’t).
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2026/04/ghost-newsletter-content-settings.png)
### Header image
Including a custom header image with your email newsletters is optional. To add a header image, click the upload icon and select your image. We recommend using a 1200x600 `.PNG` with a transparent background for the best results on any background color.
### Publication title
Email newsletters can be configured to show or hide the publication title, which can be customized from the **Settings → General** area of Ghost Admin.
### Newsletter name
When enabled, this specific newsletter’s name will be displayed under the publication title, and is best used when you have multiple newsletters.
### Title section
Control whether or not the **post title**, **post excerpt** (subhead), or **feature image** shows at the top of each newsletter.
### Footer
The email footer area can be customized to collect audience feedback, link to commenting, share your latest posts, include a share button, or show subscription details, as well as include any additional text or legal information you’d like to appear at the bottom of your newsletters.
### Promote independent publishing
The "Published with Ghost" badge can be enabled or disabled from appearing at the bottom of each newsletter. It’s not required, but always appreciated! 🙏
## Design settings
This section allows you to control the look and feel of your newsletters, ensuring your brand stays consistent across both web and email.
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2025/06/image-2.png)
### Global
These settings set the foundation for your newsletter design. Set your email's **background color**, choose **fonts** for both headings and body text, and control your **heading weight**, for a bold and splashy or light and minimalist feel.
### Header
These settings apply to the top section of your newsletter. Here you can set your **post title color** and **alignment**, in addition to a separate **header background color** that will *only* apply to this top section, letting you do things like this 👇
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2025/06/image-3.png)
### Body
These settings give you more fine-grained control over how your content appears specifically in newsletters.
- **Section title color** → Sets the color for all headings within your newsletter content, helping you create visual hierarchy.
- **Buttons** → Customize your CTAs with corner style (square, rounded, or pill), appearance (filled or outline), and color to match your site's button style.
- **Links** → Control how links appear with custom colors and styles (underlined, regular, or bold) to ensure they stand out or blend in, whichever you prefer.
- **Image corners** → Choose rounded corners for a friendly, approachable feel or keep them square for a clean, professional look.
- **Divider color** → Style the horizontal lines between sections to subtly reinforce your brand colors.
## Need some inspiration? Here are a few examples we like:
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2025/06/example_1.webp)
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2025/06/example_3.webp)
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2025/06/example_2.webp)
