> ## Content Index
# Customizing Stripe
- URL: https://ghost.org/help/customizing-stripe/
- Published: 2026-10-21T13:41:56.000Z
- Updated: 2026-10-21T13:44:04.000Z
- Author: Ghost
- Tags: Payments, Manual
When members decide to upgrade to a paid tier, they will complete their purchase via a Stripe Checkout page. This page can be customized directly within Ghost Admin, from the **Settings > Tiers > Checkout** area.
You will need to [connect Stripe](https://ghost.org/help/stripe/) and setup at least one [paid tier](https://ghost.org/help/tiers/) before checkout settings can be customized.
## Look & feel
In order to customize your design, you will first need to enable the checkout design settings. When enabled, this will override the checkout styling in Stripe.
0:00
/0:14
1×
The available options that can be customized include:
- **Background color**
Apply a custom background color to your checkout page
- **Accent color**
Use your site’s accent color, or select a custom accent color for your Pay button
- **Corners**
Choose between square, rounded or pill corners
- **Checkout font**
Choose a custom font that fits your brand design
You can also preview how your changes will display during checkout using the **Preview in Stripe** option, allowing you to see how checkout will look for each tier.
When finished making your changes, hit **Save** to push them live on your publication.
