> ## Content Index
# Adding styles with code injection
- URL: https://ghost.org/help/code-injection-styles/
- Published: 2023-04-18T13:27:43.000Z
- Updated: 2025-08-01T20:27:35.000Z
- Author: Ghost
- Tags: Design, Manual
Code injection in Ghost allows you to easily add CSS styles, custom fonts, meta tags, and scripts to your site header and footer.
![](https://storage.ghost.io/c/69/0f/690faecc-18d1-42c5-a99a-83ce5fada384/content/images/2023/10/Code-injection-1.png)
To access the code injection feature, go to **Settings → Advanced → Code Injection** area of Ghost admin.
Code added within the Site Header will be output within the `<head>` `</head>` of your site, and the code added to the Site Footer will be placed before the closing `</body>` tag.
When using code injection, any custom CSS or scripts you add will appear on every single page of your site – without having to edit your theme files directly. You can also use code injection on individual posts and pages from within the Editor, in the [Post Settings menu](https://ghost.org/help/post-settings/#code-injection).
Below are a few common examples of CSS that can be used to make changes to your site design, if using our default theme, [Source](https://ghost.org/themes/source/):
**Increase the logo size in the header**
<style>
.gh-navigation-logo img {
    max-height: 40px; /* increase value to increase logo size */
</style>
**Remove Ghost branding from the footer**
<style>
.gh-footer-copyright {
   display:none;
</style>
**Change the direction of elements and text to right-to-left**
<style>
  body {
    direction: rtl;
</style>
For more examples, check out the [Code injection tutorial](https://ghost.org/tutorials/use-code-injection-in-ghost/).
